Currently (as of release 11.1) service webhooks only support non-hosted data (data in an enterprise geodatabase) where the data is not registered as versioned.
Working with versioned data is a central part of many workflows using either branch or classic versioned data.
Support for webhooks in these workflows would be a great improvement.
Outside of the ESRI world, stored procedures and triggers are used in the database (Oracle, SQL Server, etc.) instead of webhooks. This is a more direct solution which doesn't have to leave the database for execution.
Support for branch versioned feature services was added at ArcGIS Enterprise 11.3.
