ArcGIS Urban API Questions
68
26.7K
6
POST | Hi,I am using the Urban API with python. I would like to get a list of all UrbanDesignDatabases within a UrbanModel t... by MaximeDemers Occasional Contributor III 1 3 | 1 | 3 | 410 | |
POST | I'm working with a client using the Urban API to generate buildings. While they are able to use createLOD1Buildings m... by RobStauder Occasional Contributor 1 3 | 1 | 3 | 449 | |
BLOG | 2 | 0 | 353 | ||
BLOG | ArcGIS Urban API was shipped with the following new features:A custom `OptIn` directive to enable experimental featur... by AgnieszkaRozniak Esri Contributor 3 0 | 3 | 0 | 370 | |
POST | Hi,I am trying to retreive all the projects from a Urban model including those of UrbanDesignDatabases.I am using the... by MaximeDemers Occasional Contributor III 0 8 | 0 | 8 | 1095 | |
POST | Hi, I am using the Urban API to create parcels in batch, but sometimes I am facing the 504 timeout error even if I ke... by MaximeDemers Occasional Contributor III 0 3 | 0 | 3 | 999 | |
BLOG | The most important changes include:A new Meta field containing additional information about objects - for example, ob... by AgnieszkaRozniak Esri Contributor 2 0 | 2 | 0 | 641 | |
BLOG | The most important changes include:adding a new createUrbanModel operationadding sorting capabilities to the followin... by AgnieszkaRozniak Esri Contributor 0 0 | 0 | 0 | 791 | |
POST | Hi,I am trying to use the Urban API with Python but I got an authentification error:GraphQL query failed with 1 error... by MaximeDemers Occasional Contributor III 1 3 | 1 | 3 | 1342 | |
BLOG | The most important changes are related to the Urban release scheduled for July 20. Changes to the API include adding ... by AgnieszkaRozniak Esri Contributor 0 0 | 0 | 0 | 938 | |
POST | Hi,I'm using the ArcGIS Urban API in a js app. I make requests to the urban api through esriRequest. Everything has b... by RobStauder Occasional Contributor 0 2 | 0 | 2 | 1284 | |
BLOG | Go to Discover the Playground for a quick introduction about how to get started with the Playground. This section als... by AgnieszkaRozniak Esri Contributor 1 0 | 1 | 0 | 1103 | |
BLOG | The latest version of the Urban API has just been released yesterday, 15. February!The most important update is the i... by AgnieszkaRozniak Esri Contributor 0 0 | 0 | 0 | 1237 | |
BLOG | Welcome and thank you for joining the ArcGIS Urban API place on GeoNet!If you landed here, you probably already know ... by AgnieszkaRozniak Esri Contributor 2 0 | 2 | 0 | 1370 |
