The user interface in the network properties dialog box in a utility network extension is lacking some usability. It is cumbersome to view the Network Properties for the different Tiers, since the Properties Dialog Box is missing a scroll bar at the bottom.
Workflow:
Right click a Utility Network and open Properties. Expand the window to full size. Click on Network Properties. Expand the domain Network and then expand Tiers. The bottom scroll bar is at the bottom of the list of Tiers, which means that if you need to look at information at the bottom of the list of tiers, the top description for the coloumns is missing. Since the horizontal scroll bar is at the bottom of the list, it also means that you cannot scroll all the way to the right of the list if you need to look at the information on the top of the list. You would then have to first scroll down to the bottom, move the scroll bar to the right, and then scroll back up again to where you need to be.
