Geodatabase Error (-2147220987): The user does not have permission to execute the operation. Esri Geodatabase (File Geodb Open API)
1386
03-14-2022 05:00 AM
GISDG
hi,
i get the following error in fme
using Esri Geodatabase (File Geodb Open API) writer.
has anyone had the same problem with using the open api? thanks to everything
Aled_Jones
ensure the database user your are using has the necessary privileged to write features/execute to the database
Additionally, check that FME is acquiring the necessary license to perform said function. Here's a handy article for setting license levels:
https://community.safe.com/s/article/setting-different-license-levels-for-arcgis-and-fm
