Hello! I am interested to find different example solutions where dashboard is able to display current data of the day with an option to observe historical data. The main goal is to find a solution where newest data linked to the certain geometry is automatically drawn to the map when the map is opened, with an option to search past days or periods of time.
Currently the problem is that the daily uploading data is always creating a new geometry to the map. When the map/ dashboard is opened, the overlapping geometries are all being loaded at the same time to the map, reducing the performance of the map/dashboard.
I would like to find a way to prevent the formation of multiple overlapping geometries, with the possibility to see past data from geometries by inserting a certain time span to the dashboard. It would be much preferred that only the latest data is added to the map, and the historical data would be loaded only when needed, so that the performance of the dashboard is not harmed by the great amount of historical data.
Please inform me if you happen to know some solutions or executions that may have something in common with my case. Thanks!
