ArcGIS for Excel edits not pushing to AGOL Hosted Feature Layer
251
03-05-2024 11:05 AM
HHight
I am currently using ArcGIS for Excel to have users edit the tabular data for a particular hosted feature layer. The edits made in Excel are not being pushed to AGOL. However, edits made in AGOL do push to the Excel spreadsheet. I've tried refreshing the data on both ends, signing in and out, and ensuring I am using the correct feature. I cannot for the life of me figure out what is going on.
Any insight that can be provided is appreciated!!
Tags (3)
Gaurav-Singh
Please clear the cache to see whether it helps - https://doc.arcgis.com/en/microsoft-365/latest/excel/faqs.htm#anchor20
Please also verify that the 'Enable Editing' option is turned on for the ArcGIS layer you would like to edit.
ArcGIS for Excel Team
HHight
Thanks for the reply!
I have ensured the data is editable. I have also cleared my cache and tried editing in different browsers. I am still unable to push edits from the spreadsheet.
Gaurav-Singh
Could you please share the dev console log with us, including of the event when you edit the sheet? If possible, I would appreciate if you could direct message me the ArcGIS layer URL so that I can attempt to use it in my environment for debugging purposes. I assume your account User type is Creator and your account Role is Publisher. Thank you.
