If I were in your shoes, I would give it a try but obviously there are other details to consider (e.g. what resources are available on the machine, is GeoEvent Server competing for those resources, are other inputs/outputs/GeoEvent services running on your instance of GeoEvent Server, etc). At a glance...
1. 1,500 point geofences doesn't seem alarmingly high. They have simple geometries (x,y) which is a major plus. I'd be more concerned if you had 1,500 complex polygons (i.e. high vertices count).
2. Updating those AVL "geofences" every minute doesn't seem all that bad either. That is within the scope of what a stream service (for a sync rule) could support (but again, this is based on the other factors I mentioned above).
3. This is the biggest question; how many areas are there? Are they complex polygons? How frequently are you looking to check them for truck intersection? If they're simple polygons, there aren't many, and you only need to see their point-in-time status once every minute or so, this could work. If your answer is the opposite (i.e. they are all complex polygons, you have hundreds instead of dozens, and you need them updated every 5 seconds, then that could be an issue where you see performance bog down some and not keep up in real-time).
Again, if I were in your shoes I would put together a pseudo proof of concept and see how it works for you. That's really the best way to know for certain (especially because there are other factors that could be at play like I mentioned above that I am personally not aware of).
In the event that you find its not what you want, there can be other ways to potentially go about your problem. For example you could track the trucks again and geotag them with the name of the geofence area they intersect with. In another field you could have the name of the area they're assigned to. If the geofence (geotag) name field == the assigned area name, there might be a way to use that condition to affect another GeoEvent Service to update a separate areas dataset to have an area status set to covered. This might require some more tinkering/logic though.
