Currently, the Editor widget allows the user to view the fields of an existing feature only after he/she clicks on the "Select" on the widget and then the feature. Expedite this process by allowing the attributes to appear on the form when the user clicks on the existing feature without the need to click on the "Select". If there is a feature to click on then there is a form associated with it. In WAB's smart editor it does just that. Click on the feature, it shows the form.
