JavaScript Maps SDK Blog
200
354.2K
62
Open | I noticed that during i3s requests, usually a node is accompanied by multiple requests such as geometries, textures, ... by 海洋2021 New Contributor II 0 0 | 0 | 0 | |
Under Consideration | Remove limitation :See : https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-FeatureRed... by FlavieMoraux New Contributor III 2 4 | 2 | 4 | |
Needs Clarification | Is it possible to add 2 arrows, a first one who represent the wind direction and strength based on an array, a second... by JohnVanMeenen New Contributor 0 1 | 0 | 1 | |
Open | Hi everyone,I wanted to bring to your attention a sample example at "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arc... by ManishGohil New Contributor III 0 0 | 0 | 0 | |
Open | Enhancement featureReference Scale based scaling of Graphics in a GraphicsLayer.Enhancement categoryGraphicsLayerEnha... by SebastianFrey1 New Contributor II 7 0 | 7 | 0 | |
In Product Plan | It would be helpful for some use cases to have the ability to pass different highlight options when calling a method ... by mleahy_cl New Contributor III 1 6 | 1 | 6 | |
Open | We're migrating our webmap from 3.x to 4.x.On the current webmap, there are several layers which need to be thematica... by nadja_swiss_parks Occasional Contributor II 8 4 | 8 | 4 | |
Open | It should be possible to add multiple popups? view.popups = []; Add popups manually with viewHitTest -> view.popup.ad... by MichaelK1 New Contributor III 2 1 | 2 | 1 | |
Under Consideration | The ArcGIS JavaScript API 4.x supports a 12 hour AM/PM format on the timeslider today, however, many disciplines use ... by KarlLarsen New Contributor III 2 6 | 2 | 6 | |
Open | ArcGIS JavaScript API 4.x Feature Table widget ("esri/widgets/FeatureTable") should allow users to specify the list ... by Kishore Occasional Contributor 4 1 | 4 | 1 |
Idea Submission Guidelines
