Correct the creation of polygons in a shapefile layer that is not saved in a GDB
381
01-16-2024 01:33 PM
Status: Closed
tempLeidyGarcía
New Contributor II
Because when creating a polygon in a shapefile layer outside of a gdb, the element disappears from the layer but its properties are saved in the attribute table. It would be great to review how to correct this flaw, it may be by optimizing the visualization or improving the editing of these entities.
Tags (3)
2 Comments
Scott_Harris
@tempLeidyGarcía features from shapefiles shouldn't disappear when editing. Perhaps the shapefile has a bad/missing spatial index or something else is going on?
More on how to modify a spatial index: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/modifying-a-spatial-index.h...
If recalculating or removing/re-adding the spatial index doesn't resolve it, please call Esri Technical Support for them to investigate a possible bug.
Scott_Harris
Status changed to: Closed
@tempLeidyGarcía I'm closing this since the recommendation is to contact Esri Technical Support should this occur again.
