If you change the sort for a column such as Name in the 'Open Project' dialog window the setting is not remembered next time you open the dialog.
Example:
You want to open a project that is named Z123. You set the Name column to sort descending, find, and open your project. Once done you want to open the next project named Y456.
When you open the dialog the Name field is sorted per defaults with folders at the top and files alphabetically ascending. You either have to sort again or scroll to find you file which is inefficient.
