undefined reference to `QFutureInterfaceBase::setContinuation(std::function<void (QFutureInterfaceBase const&)>, QFutureInterfaceBasePrivate*)@Qt_6_PR
252
04-28-2024 10:06 PM
AnkitaDey
:-1: error: /home/traana/arcgis/maps_sdk/qt200.4.0/sdk/linux/x64/lib/libEsriCommonQt.so: undefined reference to `QFutureInterfaceBase::setContinuation(std::function<void (QFutureInterfaceBase const&)>, QFutureInterfaceBasePrivate*)@Qt_6_PRIVATE_API'
getting the above error, while using arcgis sdk for qt 200.4 with qt 6.6.3 framework in fedora linux. Checked with gcc, clang version, seems to be compatible, add the environment variables. Still it's not getting resolved.
NhanVo
Hi, any update on this, we also encounter the same problem with Linux ubuntu 22.04, qt 6.7.0 and 200.4 Esri runtime sdk.
JimTekever
I'm also experiencing this issue on Kubuntu 22.04 and Qt 6.6.1 (compiled from source), with both 200.4.0 and 200.3.0. I can confirm that my libQt6Core.so has a function with the signature:
QFutureInterfaceBase::setContinuation(std::function<void (QFutureInterfaceBase const&)>, QFutureInterfaceBasePrivate*)@@Qt_6
Which is a match except for the @Qt_6_PRIVATE_API at the end.
JimTekever
I have managed to resolve this issue by compiling Qt 6.6.0 from source and using that instead; it looks like this is a regression introduced with 6.6.1.
