Error: Service contains unsafe html content - [Description]. Any ideas?
1735
09-12-2016 12:03 AM
PaulDoherty3
Has anyone else seen this error before?
It appears when I try to publish an editable feature layer from a service URL but I cannot figure out the cause. It is a layer I published earlier from ArcGIS Pro and there is nothing special about it. If I don't find a solution tonight I will put in an Esri Support Ticket and post back here on what I find.
KGerrow-esristaff‌?
KellyGerrow
Esri Frequent Contributor
As some follow up, this was caused by the following bug: BUG-000099728. As a workaround, ensure that there is no text in the description field of the Map in ArcGIS Pro when publishing.
KellyGerrow
Hey Paul,
Is the source URL and the url with the error publicly available? If so, can you share them?
Cheers,
Kelly
PaulDoherty3
http://eaglegis.maps.arcgis.com/home/item.html?id=935781f12be8460dba8826b5fafa1519
http://services.arcgis.com/XTtANUDT8Va4DLwI/arcgis/rest/services/Worksite_Triage_Form_Layer_Template...
Here are the settings on my end. I am able to use other services with no problem, but it seems to be either because I am publishing from Pro or a setting on the service / item page.
KellyGerrow
