Remove duplicates in attribute field
220
04-29-2024 12:23 AM
CPoynter
Occasional Contributor III
I have a field with space delimited values eg.:
26199 42448 42448 42454 42483 42497
Tried using pandas etc to explode, strip, split, etc. to list values and recreate as unique values to remove duplicates. Nothing seems to be stringing together to get my desired result:
26199 42448 42454 42483 42497
 I have several thousand rows and need to check for duplicates for all of them, and then update the row values.
Cheers,
Craig
DanPatterson
MVP Esteemed Contributor
code block
import numpy as np
def rem_dups(row, sep=' '):
    """Remove duplicates in a string in a row separated by `sep`"""
    s = row.split(sep)
    a = np.array(s)
    u = np.unique(a)
    return " ".join([i for i in u])
row = "26199 42448 42448 42454 42483 42497"
'26199 42448 42454 42483 42497'
expression
rem_dups(!YourFieldName!, sep=' ')
... sort of retired...
BlakeTerhune
MVP Regular Contributor
Does the order of these values matter after you remove duplicates?
