Reference: Calculate Distance.
Date: 2017-08-22
Do the following:
Pre-logic Script Code:
""" input shape field: returns cumulative distance between points
dist_cumu(!Shape!) #enter into the expression box"""
x0 = 0.0; y0 = 0.0; distance = 0.0
def dist_cumu(shape):
global x0; global y0; global distance
x = shape.firstpoint.X; y = shape.firstpoint.Y
if x0 == 0.0 and y0 == 0.0:
x0 = x; y0 = y
distance += math.sqrt((x - x0)**2 + (y - y0)**2)
x0 = x; y0 = y
return distance
calculation field =
dist_cumu(!Shape!)
NOTES:
If nothing is selected in the table, then the calculation will proceed from the first point and the cumulative distances will be done in sequential order. If you have 3 or more points selected, then it will calculate the values with just the selection. No cannot rearrange the order...write a script, there is only so much you can do in the field calculator.
For distances between sequential point pairs (not cumulative), use the dist_between function.
Do the following:
""" input shape field: returns the distance between points and its center
dist_between(!Shape!) #enter into the expression box"""
x0 = 0.0; y0 = 0.0
def dist_between(shape):
x0 = x; y0 = y
distance = math.sqrt((x - x0)**2 + (y - y0)**2)
x0 = x; y0 = y
return distance
calculation field =
Notes:
Make sure you have projected data and a double field or nothing will make sense. The same comments apply to calculations using selections as mentioned above.
