Web AppBuilder Notes: Themes, Widgets, and Attributes
2580
08-23-2017 04:39 PM
Note: This article refers to Web AppBuilder for ArcGIS (Online Edition) dated December 2018 and Web AppBuilder for ArcGIS (Developer Edition) 2.11 (January 2019).
Web AppBuilder for ArcGIS supports 10 out-of-the-box themes determining the look and feel of your application. The choice of theme impacts the widgets you can add to your app as well as the attributes you can modify to brand your app. The following tables document the relationships between themes, colors and layouts, themes and widgets, and themes and attributes. Each theme was designed with a use in mind. Refer to the Web AppBuilder help articles Theme, Widget, and Attribute for more information.
Theme colors and layouts
Each theme supports a fixed number of default colors, plus one customizable color. Each theme also supports from 1 to 5 layouts controlling the placement of widgets and attributes.
Theme
Colors
Layouts
Billboard
8
Box
8
Dart
8
Foldable
8
Dashboard
Launchpad
Jewelry Box
8
Plateau
8
Tab
8
Pocket
8
Themes and widgets
Each theme supports a collection of off-panel widgets you can turn on/off and may support additional on-screen widgets (widgets which are placed on the map) or a widget controller.
Theme
Built-In Widgets
On-Screen Widgets
Widget Controler
Billboard7 of 105 spotsNo
Box1 of 10NoBox Controller with 2 preconfigured widgets
Dart0 of 6NoDart Controller with 3 preconfigured widgets
Foldable8 of 115 spotsHeader Controller with 2 preconfigured widgets
Dashboard2 of 125 spots / 5 additional widget locationsNo
Launchpad8 of 114 spots with 1 preconfigured widget
Anchor Bar Controller with 2 preconfigured widgets
Jewelry Box8 of 103 spots plus 1 drawer widget
Plateau4 of 11NoHeader Controller with  2 preconfigured widgets
Tab11 of 133 spots Sidebar Controller with 2 preconfigured widgets
Pocket1 of 101 spot None
Themes and attributes
The choice of theme determines whether or not your app can have a logo, title, subtitle, and links to additional information.
Theme
Attribute
Billboard
No logo, No title, No subtitle, No links
Box
No logo, Title, No subtitle, No Links
Dart
No logo, Title, No subtitle, No links
Foldable
Logo, Title, Subtitle, Links
Dashboard
Launchpad
Logo, Title, Subtitle, Links (expandable link object)
Jewelry Box
Plateau
Tab
Pocket
Comments
Anonymous User
I don't like the way "Legend" and "Layer List" are separate widgets that have to be selected. Is it possible to show the information from both on one widget? - All layers with their symbolization?
Thank you,
Randy McGregor
Anonymous User
Randy McGregor‌ - you have seen that if you click a layer's name, it expands to show its legend swatch, right? Does that not do what you want, in terms of behavior?
This is a great summary post, thanks Rudy!
Anonymous User
I did know that, but thanks for the reminder. I like having the legend always visible, showing what is turned on.
I found that it is VERY  easy to merge the legend and the layer list by simply dragging one widget over the other.
Randy
Version history
Last update:
‎08-23-2017 04:39 PM
Updated by:
Contributors
