Esri Production Mapping
3637
06-27-2014 11:36 AM
Esri Production Mapping helps organizations that create and maintain large amounts of authoritative geospatial content to achieve economies of scale by managing and publishing consistent, constant GIS data and cartographic products on strict schedules. With Esri Production Mapping, you can provide a shared work environment for teams of any size to improve the quality and value of your geospatial data and cartographic products through standardization, repeatability, and configuration of your production processes.
  • Generate specification-driven output through reliable, consistent processes.
  • Centralize GIS workflow creation and management to ensure consistency across operations.
  • Enhance user productivity by standardizing feature collection and validation, cartography, workflows, and data management.
  • Streamline data creation with additional templates, construction tools, and on-the-fly feature attribution and validation.
  • Implement an efficient review process by automating tasks for spatial data quality control.
  • Standardize and centralize detailed cartographic production with tools for creating and maintaining derived data, symbology, page elements, and maps.
  • Reduce time spent manually producing multi-scale products by using map automation and generalization tools.
Increase the efficiency of GIS data creation using on-the-fly- feature validation.
Comments
Hi Everybody!
Does anyone know if there are plans to create the Product Library functionality in ArcGIS Pro? I mean the same functionality of central management of cartographic products (solutions, map series, sheets) as in Esri Production Mapping for Desktop (ArcMap).
And also..., the same functionality of the ArcMap tool  - graphic table element: https://desktop.arcgis.com/en/arcmap/latest/extensions/production-mapping/what-is-a-graphic-table-el...
Can I found it in ArcGIS Pro?
Tomek
Hi Tomek,
Thank you for your post.
Product Library functionality previously referred to as 'Projects in the Enterprise' in previous ArcGIS Pro Roadmaps is now referred to as Portal Projects for ArcGIS Pro and is slated as Near-term. Please refer to the ArcGIS Pro Roadmap - February 2023 at the following link:
https://community.esri.com/t5/arcgis-pro-documents/arcgis-pro-roadmap-february-2023/ta-p/1261591
Regarding where to find Graphic Table Element functionality in ArcGIS Pro, please refer to on how to add and modify table frames at the following link:
https://pro.arcgis.com/en/pro-app/latest/help/layouts/add-and-modify-table-frames.htm
Please see a brief video tutorial on how to work with a table frame at the link below:
https://pro.arcgis.com/en/pro-app/latest/help/layouts/work-with-a-table-frame.htm
Regards,
Dan
Version history
Last update:
‎06-27-2014 11:36 AM
Updated by:
Contributors
