Klamath Strategic Habitat Conservation brings you...
Tasseled Cap for Landsat 8 - in a toolbox!
Input is a folder of L8 data.
Hi Daryl,
thanks for your tbx.
Unfortunately I've some problems with the installation.
1) I've just put in the C:/programs/arcgis/.../toolbox folder, and then
2) in ArcGIS -> right click on ARCtoolbox -> add toolbox.
When I run the tbx it doesn't work...
Maybe the scrips is missing...
Could you give me any suggestions?
Thank you very much
Mario
P.S. I'm using ArcGIS 10.3
Hi
Thanks for sharing..
As Mario said, script may be missing because the path shows as below,
'U:\04_Programming\20_GitHub\LandSat8_TasseledCapTransform\funL8TasseledCap_tbx.py
Thanks again
if you are still interested, you can find the solution of your problems here:
Re: How to perform Tasseled Cap Function/"Greenness" Factor in GIS?
Cheers
