AddShapefile with remove option
4858
09-18-2015 08:07 AM
Hi, I made some changes to the add shape file widget Robert send to somebody as a test, I add some code to be able to remove the shape file you added to WAB ( some words are in Spanish in the widget) I think this could be helpful for someone, just  make it international or change it to English
So, Finally I was able to upload it as a file to GeoNet, thanks Robert!
Comments
Diego, Since you started this as a new document....can you edit this post and move your description.  I'll add a link to this on the resource list.  thanks.
EDIT: Thanks Robert!
Diego, is there a version for Webapp builder 1.2? or it can work for this version too?
Hi Min,
Yes it does, it works in 1.2
Hi Diego, How do I only add polygon files?
Version history
Last update:
‎09-18-2015 08:07 AM
Updated by:
Contributors
