ArcGIS Pro silent install script (1.3 and later)
Document created by curtvprice Champion on Nov 2, 2016Last modified by curtvprice Champion on Jun 7, 2017
Version 3Show Document
  • View in full screen mode
This is in good old DOS batch language. So far, pro updates don't require an uninstall, so you can just rerun it with a new version. In theory, this script could be used to create an SCCM package for automated deployment to many desktops.
:: install_arcgispro.bat
:: Silent install of ArcGIS Pro
:: INSTRUCTIONS:
:: 1) Edit this script as instructed below in the comments
:: 2) Save with ".bat" extension
:: 3) Open an administrative command window.
:: 4) Run this install script from the command line
::    Alternatively, deployment software can be used to run the script.
:: Required files, this script assumes the script is in the same
:: folder as the "Esri" folder below:
:: \---Esri
::     +--ArcGISPro
::          ArcGISPro.cab
::          ArcGISPro.msi
::          *.msp files (if any - for example 1.4.1 patch to 1.4)
::     +--ArcGISProHelp
::          ArcGISProHelp.cab
::          ArcGISProHelp.msi
:: References:
:: * ArcGIS 10.4 / Pro 1.2 Enterprise Deployment
::    http://support.esri.com/white-paper/3522
:: * ArcGIS Pro installation guide:
::   .\Esri\ArcGISPro\Documentation\install.htm
:: Author: Curtis Price, cprice@usgs.gov
:: History:
:: 01/30/2015 ArcGIS Pro 1.0 - Initial release
:: 08/19/2015 Added .NET 4.5 check
:: 11/02/2016 Update for Pro 1.3 / 1.3.1
:: 06/07/2017 Setup to apply any .msp files in Pro .msi folder
:: This software is provisional and subject to revision; it has
:: not been thoroughly reviewed or received USGS final approval.
:: Users are cautioned to consider carefully the provisional
:: nature of the code before using it for decisions that concern
:: personal or public safety or the conduct of business that
:: involves substantial monetary or operational consequences.
@echo off
:: %~d0%~p0 is folder where this script resides
set SRC=%~d0%~p0
set LOGDIR=%TEMP%
set INSTALLDIR=C:\ArcGIS\Pro
::                PLEASE DO NOT EDIT BELOW THIS LINE
:: Check for .NET 4.6.1 x64
set x64key=HKLM\SOFTWARE\Microsoft\.NETFramework
if not defined ProgramFiles(x86) goto win32
:: 4.6.1 x64
%WINDIR%\system32\reg.exe query %x64key%  /f ".NETFramework,Version=v4.6.1" /k /s >NUL ^
  || ( echo. & echo ** Microsoft .NET Framework 4.6.1 ^(x64^) not installed! ** & goto dotnet_fail)
echo Microsoft .NET Framework 4.6.1 ^(x64^) verified
goto dotnet_ok
:dotnet_fail
echo ** .NET Check Failed -- Cannot Install ArcGIS Pro **
goto :eof
:dotnet_ok
echo ** .NET Check Passed **
echo.
net session >nul 2>&1
if %errorLevel% == 0 (
  echo Administrative permissions confirmed.
) else (
  echo Current permissions inadequate
  echo ArcGIS Pro install failed
  goto :eof
:: Set log file path, prefix at install script runtime
:: Example LOG_PATH result: "%LOGDIR%\ArcGISPro_20120925_1623"
:: (%LOGDIR% is set above)
set DATESTAMP=%DATE:~10,4%%DATE:~4,2%%DATE:~7,2%
set TIMESTAMP=%TIME:~,2%%TIME:~3,2%
set TIMESTAMP=%TIMESTAMP: =0%
set LOG_PATH=%LOGDIR%\ArcGISPro_%DATESTAMP%_%TIMESTAMP%
set SILENT=/qb- /passive /norestart
:: Installation starts here
@echo on
:: Install ArcGIS Pro for all users of this computer
msiexec /i "%SRC%\Esri\ArcGISPro\ArcGISPro.msi"  ALLUSERS=1 INSTALLDIR=%INSTALLDIR% ^
  /l+ie "%LOG_PATH%_Pro.txt" /l+ie "%LOG_PATH%.txt"  %SILENT%
:: patch updates (.msp files (if any) should be placed in folder with ArcGIS Pro msi
pushd "%SRC%\Esri\ArcGISPro"
for %%p in (*.msp) do %MSIEXEC% /p %%p REINSTALLMODE=omus %SL%
popd
:: ArcGIS Pro Help (optional local install [web help is also available])
msiexec /i "%SRC%\Esri\ArcGISProHelp\ArcGISProHelp.msi" ^
  /l+ie "%LOG_PATH%_Help.txt" %SILENT%
:: Optional: Set registry key to block ArcGIS Pro update prompts
%WINDIR%\system32\reg.exe add HKLM\SOFTWARE\ESRI\ArcGISPro\Settings ^
  /v CheckForUpdatesAtStartup /t REG_DWORD /d 0 /f
4 people found this helpful
    Outcomes
