GoToXY widget
6224
8
04-30-2017 10:35 PM
GoToXY widget
This widget allow the user to insert X any Y coordinates and jump to specific point.
the widget put a mark/pin in the XY point with the option to remove the pin.
Comments
Thanks for sharing, I will add to the /blogs/myAlaskaGIS/2016/03/09/web-appbuilder-developer-edition-customization-resource-list?sr=search...‌  and /blogs/myAlaskaGIS/2017/03/04/web-appbuilder-the-custom-widgets-list-332017?sr=search&searchId=766bd...
It would be helpful if you can add a description to your post rather than just the download.  Many users are reluctant to download a file without knowing  a little more about it.
ofrigmops‌, it would be helpful to add a link to a demo map that has this widget.  As a WAB developer, I like to preview a widget in a live map before downloading it.  If you can't stand up a demo on our organization's server, you can always use GitHub gh-pages branch to stand up a demo.
is there a way to change the projection to WGS ???
The projection defined by you web map.
The widget can work in any projection
okeyy, thank you
Does the GoToXY widget add a layer to the map that can then be used in analysis?
Kacie,
   No it does not. If just adds a simple GraphicsLayer.
Can any one help me, to configure this app with WKID 32640 (UTM z40, WGS84)
thank you
Version history
Last update:
‎04-30-2017 10:35 PM
Updated by:
Contributors
