The Flood Impact Analysis solution can be used to develop flooding scenarios and visualize the impact on the existing landscape. It leverages flood depth data to analyze the impact of flood events on critical assets such as buildings, bridges, low water crossings and roads. It also can be used to create compelling 3D visualizations that make it easier to understand and communicate the real impact of flooding events.
Benefits
The flood impact analysis solution template leverages flood depth data to analyze the impact of flood events on critical assets such as buildings, bridges, low water crossings and roads. You can:
Example: Operations Dashboard for ArcGIS
The following software is required:
It would be helpful for us to know:
For comments, questions, bug reports, new requirements: email gvanmaren@esri.com
