How do I create a 3d layer with max height and min height with slope ratio
317
08-22-2019 06:59 AM
JohnMcCleary
I am trying to create a 3d surface in Pro with a layer that has maximum height and minimum height values as well as slope ratio. I have various polygons that have different values. For example: One surface needs to render at a min height of 150' to a max height of 350' at a 20:1 ratio over the 4000'. A second example is a min height of 200' to max height at 1200' at a ratio of 40:1 over 10000'. Is there code/formula that I can use that will do this? This is for an airport safety area (without trying to use the Airports extension).
