arcglobe 10.1 show layer at all distances
684
11-13-2013 02:30 AM
PaulCote
I have been an arcglobe user for a long time, but this is my first time since version10.1.  It seems that the layer property, "Show Layer at All Distances" is now being ignored.  That is, whether I have the option checked or not, and no matter what I set as the maximum distance, these settings make no difference.  For a layer of buildings, the smaller ones begin to be weeded out of the display once you get above 500 meters or so.  I have tried playing with the units setting in the Globe Properties, and have also tried setting the max visibility distance by right-clicking on the layer, and toggling the option to consider tiles individually.  None of these seem to make any difference.  I have also tried rebooting and using different feature classes.  All of this worked as expected in previous versions of ArcGlobe.
Any advice?
Thanks.  Paul Cote
TimBarnes
Just to check you have also set the scale in the 'Feature Properties' (the one where you set if the layer is 'city blocks' etc)?
I would also clear and then increase the size of your cache (Customise > ArcGlobe Options > Display cache), check 'Automatic LOD tuning' is turned off in the 'Level of Detail' tab and move your far clipping plane out (View > View Settings)
