Hi all,
I figured this should be easier than I have found so I thought I would post this before manually entering or using attribute transfer mapping. I have a feature class with 250+ points that have an elevation field. These are surveyed points of a pipeline. What is the most efficient way to create a ZM line for display in ArcScene/Globe? Currently I am looking at creating individual segments of lines connecting each point and then populating Elevation1 and Elevation2 fields in the line feature class using the attribute transfer mapper. With 250+ points and 2 clicks per Elevation field that is over 1000 clicks and a lot of time.
Who can shed some light on a better way to do this.
Jared
