Why are LAS, and Terrain Datasets not acceptable formats as an elevation source? Terrain Dataset is an ESRI elevation surface format??? Converting these high resolution datasets to other formats is such a waste of processing time.
Elevation sources
An elevation source contains the data that defines the elevation surface. An elevation surface can have more than one elevation source, and you can combine different types. Local elevation sources can be either a raster that contains elevation information or a TIN dataset. LAS datasets and terrain datasets cannot be used as an elevation source. You can also use an elevation image service as an elevation source or a portal web elevation layer. You can find elevation layers on ArcGIS Online by searching for the keyword elevation. If you use custom image services, make sure you have elevation defined as the service type.
