Scene Symbols
1060
01-17-2017 06:12 AM
GeoNet
New Contributor III
The change to be able to use symbols in Scene is very welcome.
1: A bug? When altering the range, no matter what minimum you choose, it goes back to 1.  Only after that can you reliably change it to another number.  It would be good to fix this.
2: When choosing symbols, if you then decide something else would look better, it would be helpful for the existing symbol to be highlighted to differentiate it from the others.
3: With realistic symbols, some names would be useful e.g. for the trees - are they actual examples of trees (e.g. oak, beech) or generic (e.g. broad leaved deciduous).
4: With trees in particular, when you choose a range colour rather than a solid colour, the trees take on a slightly odd see-through quality when seen against the sky which makes them look less realistic - they let a bit too much sky through.
Tags (3)
