Sun Shadow Volume - how to create sequence of shadows
4969
12-23-2012 03:21 PM
JaroslawKowalczyk
I have just spent a day trying to create sequence of shadows and finally decided to ask if it is possible. I have created surface (tin), extruded polygon (something like a building) and used "Sun Shadow Volume" tool to create sequence of shadows. I entered following parameters:
input features: my extruded polygon
start date and time:  2012-12-24 02:12:15
output feature class: my output feature class
adjusted for ...: true
time zone: according to system locale
end date and time: 2012-12-28 02:12:15  (simply a few days later)
iteration interval:  1
iteration unit: hour
I thought (was sure) it will produce something like: 4 days * 24h = 96 shadows, but I was wrong. It produced only 4 shadows, each for 07:58:55 (or close to it) every day.
Is this behavior normal? How can I get output for every hour for a few days.
I think I must have misunderstood tutorial/ArcGIS help, or maybe there is any bug in this tool.
Do you have any experience in this field?
Jarek
Tags (1)
YingYeung
Hello,Jarek.
I want to create shadow but I got errors.
I also input the extruded polygon and using sun shadow volume tool to do that but there is no surface (tin).
input features: extruded polygon
start date and time:  2015-1-25 07:00:15
output feature class: output feature class
time zone: UTC +8
end date and time: 2015-1-26 07:00:15
However, the result shows that the output feature is empty and there is an error (999999).
Anyone can help me to solve this? Thanks a lot.
Ying
YingYeung
Finally, I created some shadow but I also have the same problem with you.
I do not know how to set the iteration unit and interval too.
Can anyone help me ?
Thanks a lot.
