Hi, I have problem with data in Oracle. In database using SQL developer I have added new data. Unfortunately this data is not visible in ArcGIS.
1229
01-13-2017 02:47 AM
AdamBielecki
I am logged as this same user in both software's. Of course I have committed all changes, even reconnected to DB. Only part of data is not visible. What could be a reason of that?
Tags (1)
VinceAngelo
Esri Esteemed Contributor
Are you editing a versioned feature class?  Does the deletes table remove the base table rows you have edited in favor of a newer version? All edits to versioned tables should be made with version-aware means.
