Add Bing Base Map to Flex Application
4968
12-23-2014 08:09 AM
MelO
Hi all,
I need help using the Bing map as a basemap in a Flex application.
I can add an ESRI basemap to my AGOL maps because I can get it from the basemap gallery.
But the link that the ESRI bing map is based on isn't working: http://www.esri.com/software/arcgis/arcgisonline/bing-maps.html
What REST link URL should I use to add the Bing basemap to a Flex application?
Thanks.
AnthonyGiles
Melissa,
Are you using the flex viewer or creating your own app using the api.
For the viewer, see the help here:
ArcGIS Viewer for Flex
For the api see this help:
com.esri.ags.virtualearth.VETiledLayer
Regards
Anthony
