Hi all,
I've been browsing threads and tech articles/blogs for similar issues, with no luck.
I'm trying to display maps provided by a server placed in our internal network (with private IP 10.16....), through a sample flex viewer 1.3 served by the "external" web server (with public IP 193.206....).
The firewall allows these two servers to dialog via port 80.
I assume that simply placing a crossdomain.xml file in the root of the "private" server would not solve the problem, because the private IP would not be accessible to any machine in the outer world (in fact, I naively tried to do that, with no success).
I was not able to understand if and how this situation could be solved using a proxy, or if the only way out is to place the server outside the private network.
Thanks in advance
Nicola
