ArcGIS Viewer for Flex: adding a custom model
1000
08-13-2012 07:59 AM
katiem
Hello,
I am new to ArcGIS Viewer for Flex and was wondering if I could input a model that would run in the viewer. I want an interactive website where the user can put in a lat/long coordinate and then create a point shapefile from that and then run in an Arcgis model I created and output the results on the map. Would ArcGIS Viewer for Flex be able to do this??
Thanks so much
Katie
IanKramer
New Contributor III
Hi Kate,
That is possible.  I would start here: http://resources.arcgis.com/en/help/main/10.1/index.html#/What_is_a_geoprocessing_service/0154000004...
Then look at the Clip and Ship GP Tutorial.  It's close to what you want to do.
http://resources.arcgis.com/en/help/main/10.1/index.html#//005700000073000000
Then I believe you can use the Geoprocessing widget which is part of the FlexViewer core.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Geoprocessing_widget/01m3000000...
Hope that helps!
Ian
