Hello Bjorn,
Thanks for the document. Indeed Geometric Network is working 🙂
I spent one entire day testing this and everything seems to work just fine except the refresh of the map. I'm using the selection mode in the FeatureLayers and an ArcGISDynamicLayer as a base map mapservice.
When I select the feature on the map service as resutl I get the feature selected as graphic. When I move the graphic obviously get's updated and there is a call to applyEdits REST method.
After that the map on screen does not refresh. So I caught the event editsComplete to manually refresh the map.
Is this needed? Is this the proper approach?
José Sousa
ESRI Portugal
