Constrained Map Extent in Flex
1338
10-25-2010 03:05 PM
SandeepTalasila
Does anyone know how to apply constrained Map Extent in Flex Viewer 2.1. I found one implemented on Sample Flex Viewer 1.3. http://forums.esri.com/Thread.asp?c=158&f=2421&t=295234&mc=0. But not sure how to apply in 2.1, getting so many errors.
Thanks.
MattWilliams
Not sure if this will help you or not. This is the sample code on Mansour's blog, before it was modified for the FSV 1.3.
http://thunderheadxpler.blogspot.com/2009/01/constraining-map-extent.html
The only change I had to make to the SampleMap.as file was on line 65...
WAS: if( extent.containsExtent( m_initialExtent ))
NOW: if( extent.contains( m_initialExtent ))
Then the mxml looks something like this:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags"
      xmlns:sample="com.esri.sample.*">
 <sample:SampleMap>
  <sample:extent>
   <esri:Extent xmin="-92.957" ymin="37.674" xmax="-84.729" ymax="42.541" id="myMapExtent">
    <esri:SpatialReference wkid="4326"/>
   </esri:Extent>
  </sample:extent>
  <esri:ArcGISTiledMapServiceLayer
   url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
 </sample:SampleMap>
</s:Application>
Like I said, not sure if this will help you or not... Good Luck!
MattiasEkström
I would like this in my Flex Viewer 2.1 too, I actually tried rewriting Roberts implemetation for the SFV 1.3 to the Flex Viewer 2.1. I managed to get rid of all errors, but when I ran the application there wasn't a map at all, all was blank, that's were I gave up.
It will need a lot more modifications than changing extent.containsExtent to extent.contains, to apply this to the FlexViewer 2.1 that's for sure 🙂
SandeepTalasila
Hey Mattias,
I did those changes too... and I am having the same problem as you do... nothing shows up.
@Matt Williams: Thanks for your response.
