Im working with a PHP script that POSTs to a ArcGIS 10 Flex Server's GPService Toolbox (written in python), the first parameter is supposed to be a GPDataFile. From the documentation, it looks like I can set the value of this parameter to a json formatted string literal, {"url", "http://localhost/export/1234567890.kml"}, and the arcpy.GetParameter(0) should handle this object correctly.
Unfortunately I am receiving an error, saying 'Please check your parameters', there are two other parameters on the toolbox but they are just strings and are working correctly. I am working in ArcGIS Server 10.0. Flex viewer.
The overall goal of this interaction is to send a KML file from our SWF/ActionScript to the PHP, which saves the KML to our database and subsequently sends it to the GPService to translate it into a GDB and then to individual insert the data into oracle ArcSDE 10.0 database for rendering back to the SWF/Actionscript.
Any help our thoughts on how to get the Toolbox to accept the JSON structure would be greatly appreciated, I would like to avoid having to send the KML contents as a string object to the Toolbox.
