Hello, I am a total newbie. I downloaded the Flex Api along with the samples (arcgis_api_for_flex_2_5). I followed the instructions in the readme, but when running, I get a bunch of errors (one for each mxml).
Adobe AIR application is missing the corresponding ArcGISWebMap-app.xml. ArcGISWebMap.mxml /FlexSample/src Unknown AIR application.xml Problem ....
The same error for each mxml. There is only one xml in the project, in which was created when I create the project. The samples only provided mxml files.
Please help. Thank you.
---- This is the instruction in the readme:
======================= ArcGIS API for Flex 2.5 build date 2011-11-30 =======================
This file contains the ArcGIS Flex API Library (the swc file), skins and sample code.
=============== Getting Started =============== 1. In Adobe Flash Builder, create a new Flex project (File -> New -> Flex project).
2. Copy all the contents of the ArcGIS_Flex\samples\src folder to src folder of the Flex project created above.
3. In Adobe Flash Builder, add the API Library to the project through Project -> Properties -> Flex Build Path -> Library Path -> Add SWC (and locate the "agslib-2.5-2011-11-30.swc")
4. In Adobe Flash Builder, right-click on any of the sample mxml applications and click "Set as Default Application".
5. In Adobe Flash Builder, right-click on any of the sample mxml applications and click "Run Application".
