Can anyone help with improving the quality of my pdf in flex.
Image which is been added has very low resolution.
This is the code which I have used till now for exporting the pdf.
Thanks in advance
Regards,
myPDF = new PDF(Orientation.LANDSCAPE,Unit.MM, Size.LETTER);
myPDF.setDisplayMode(Display.FULL_PAGE, Layout.SINGLE_PAGE);
map.scaleBarVisible = true;
map.zoomSliderVisible = false;
map.panArrowsVisible = false;
setPDFPageElements(myPDF, 220, 150, "Attribute Query Output " , "", "Copyright: State Planning Commision");
myPDF.addImage(map,null,20,20,220,150,0,1,false,ImageFormat.JPG,100,Blend.NORMAL,null);
var grid:org.alivepdf.data.Grid;
var dataArray:Array = ArrayCollection(dgAttribute1.dataProvider).toArray();
grid = new org.alivepdf.data.Grid(dataArray, 0, 0, new RGBColor(0x999999), new RGBColor(0xFFFFFF),false,
new RGBColor(0x000000), 1,Joint.MITER, null);
grid.columns = createGridColumns();
var newPage:Page = new Page ( Orientation.LANDSCAPE, Unit.MM, Size.LETTER );
myPDF.addPage(newPage);
myPDF.getCurrentPage().setUnit(Unit.MM);
myPDF.textStyle(new RGBColor(0x000000), 1);
myPDF.addGrid(grid, 3.5, 3.5, true);
var file : FileReference = new FileReference()
file.save(myPDF.save(Method.LOCAL),"exportresult.pdf");
