Description Resource Path Location Type 1046: Type was not found or was not a compile-time constant: Form. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: FormItem. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: FormItem. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: FormLayout. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: GestureEvent. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: Image. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: Image. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: Image. BAAF Unknown Flex Problem 1046: Type was not found or was not a compile-time constant: TransformGestureEvent. BAAF Unknown Flex Problem
why not T^T
(I'm already import these constants, but these problems are not solved. )
close all the opened tabs, the projects then close flash builder. after start flash builder again and open the desired project then clean all the projects (project --> clean --> clean all projects).
