Hi
Im having trouble finding a solution for my problem. I have a widget which basically shows some of the attributes from a feature layer. It works fine manually displaying the attributes but there is a requirement for the widget to refresh its values when the layer is changed.
For example if I was to use the out of the box edit tool and change one of the records the other widget has to listen for this change and refresh.
I have done this sort of thing before in javascript (and in flex but within the same widget).
Is there a way to listen for the event or any other solution that does'nt invlolve using a timer that refreshes.
Graham
