MapImage not scaling correctly when multiple mapimages in MapImageLayer
2597
02-05-2013 12:10 PM
stevemclaughlin
New Contributor III
I'm using Flex 3.1 api
I've got a map and I create a MapImageLayer.
I then have 5 MapImages that I set the source to 5 .png files that I create extents for and add to the MapImageLayer using the
MapImageLayer.add(MapImage)
all looks great .... UNTIL I zoom the map and the only mapImage that scales correctly is the last one I added.
The other mapimages stay the same original size.
How do I get all MapImages to scale correctly?
(if there is not an obvious answer, I'll try to post some code)
thanks,
-steve
stevemclaughlin
New Contributor III
After some more testing, it works with non-embedded assets, and fails with embedded assets,
here is some test code:
Using Flash Builder 4.6 and Flex Arcgis 3.1 API
Run the code and zoom in or out, the images jump around, they should stay on the map.
You'll need 3 small images stored in your flex project to test it out, any small images will do.
Change the 'creationComplete="zoomWorks"' to 'zoomFails' to test it out.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags"
      xmlns:components="components.*"
      creationComplete="zoomFails()"
 <fx:Script>
  <![CDATA[
   import com.esri.ags.geometry.WebMercatorExtent;
   import com.esri.ags.layers.MapImageLayer;
   import com.esri.ags.layers.supportClasses.MapImage;
   // any small image will do
   [Embed("resources/images/mapping-charting.jpg")]
   private const img1:Class;
   [Embed("resources/images/logo-esri.png")]
   private const img2:Class;
   [Embed("resources/images/the-power-of-maps.png")]
   private const img3:Class;
   private var weathermapimage:MapImage;
   private var weathermapimage2:MapImage;
   private var weathermapimage3:MapImage;
   private var mil:MapImageLayer;
   private function zoomFails():void {
    mil = new MapImageLayer();
    map.addLayer(mil);
    weathermapimage = new MapImage();
    weathermapimage.extent = new WebMercatorExtent( -153,35,-110,50);
    weathermapimage.source = img1;
    mil.add(weathermapimage);
    weathermapimage2 = new MapImage();
    weathermapimage2.extent =new WebMercatorExtent( -3,25,38,44);
    weathermapimage2.source = img2;
    mil.add(weathermapimage2);
    weathermapimage3 = new MapImage();
    weathermapimage3.extent =new WebMercatorExtent( -111,-15 ,-70,10);
    weathermapimage3.source = img3;
    mil.add(weathermapimage3);
   private function zoomWorks():void {
    map.addLayer(mil);
    weathermapimage.source = "http://resources.arcgis.com/en/communities/_images/mapping-charting.jpg";
    weathermapimage2.source = "http://resources.arcgis.com/en/shared/rc/images/logo-esri.png";
    weathermapimage3.source = "http://resources.arcgis.com/en/home/images/the-power-of-maps.png";
 </fx:Script>
 <esri:Map id="map"   >
  <esri:ArcGISTiledMapServiceLayer id="mapsl"   url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
 </esri:Map>
</s:Application>
YannCabon
Thanks for the feedback!
There are indeed 2 issues with embedded assets in the MapImageLayer.
Here's a workaround, encode the source of the map images to byteArrays, and add them when the Map is loaded.
               xmlns:components="components.*">
    <fx:Script>
        <![CDATA[
            import mx.graphics.codec.PNGEncoder;
                map.addLayer(mil);
                var encoder:PNGEncoder = new PNGEncoder();
                var bitmap:Bitmap;
                var sourceImg1:ByteArray;
                var sourceImg2:ByteArray;
                var sourceImg3:ByteArray;
                bitmap = new img1();
                sourceImg1 = encoder.encode(bitmap.bitmapData);
                bitmap = new img2();
                sourceImg2 = encoder.encode(bitmap.bitmapData);
                bitmap = new img3();
                sourceImg3 = encoder.encode(bitmap.bitmapData);
                weathermapimage.extent = new WebMercatorExtent(-153,35,-110,50);
                weathermapimage.source = sourceImg1;
                weathermapimage2.extent =new WebMercatorExtent(-3,25,38,44);
                weathermapimage2.source = sourceImg2;
                weathermapimage3.source = sourceImg3;
    </fx:Script>
    <esri:Map id="map" load="zoomFails()" >
    </esri:Map>
</s:Application>
