setting the infowindowrenderer inline will kick off the info window, so (using the sample flayer id) you remove<esri:infoWindowRenderer>
<fx:Component>
<mx:VBox backgroundColor="0xffffff"
color="0x444444"
label="Parcel {data.PARCELID}">
<mx:Label text="Owner: {data.OWNERNME1}"/>
<mx:Label text="Address: {data.SITEADDRESS}"/>
<mx:Label text="Land Value: {data.LNDVALUE}"/>
<mx:Label text="Landuse: {data.USECD}"/>
</mx:VBox>
</fx:Component>
</esri:infoWindowRenderer>
from the feature layer (inline), then set a click event for your info button to call a function like this:private function set infoWindowRenderer(event:MouseEvent):void
flayer.infoWindowRenderer = new ClassFactory(point to an infoWindowRenderer);
you can create any custom infoWindow renderer you want in your apps assets or in a separate library and call it by package, for example assets.renderers.infoRend1. Does that help?
