Override item names in legend from graphics layer in print task
8183
10
02-06-2013 02:50 AM
JörgPossin
Hi!
I added some graphics in a graphicLayer which works well in the browser web map and also in the pdf produced with the server print task. You can see the graphics in the pdf but in the legend you see the symbols but only the item names "Override 1" "Override 2" etc. Is there a possibilty to rename the item objects in the legend from the pdf?
Here is an example:
[ATTACH=CONFIG]21491[/ATTACH]
The other 2 items are not part of the graphics layer.
JörgPossin
Hi frank_mclean,
thanks for your answer in this thread. At this time I don't have to work with our webclients but shortly I have to and then I will try your solution. It is good to know that now I can change from a static legend to a dynamically created 🙂
Jörg
