I have noticed something odd about the way the Title displays in PopUp windows which I have only started using as of last Friday, April 29, 2011. Normally, I think of the "Title" as being the line of text that is shown to the left of the close ("X") button at the top of a window, but I am finding that the content with the tag <title> in my PopUp configuration file is appearing immediately below that, and then has a thin, white line drawn below it to separate this title from the rest of the description found in the PopUp window.
Were that the only issue, then the only damage would be a little wasted space by not using the line at the same level as the close ("X") button to hold the title. However, anytime I use the Identify widget on a layer for which there is not yet a PopUp configuration, the old style InfoTemplate kicks in. This tool actually does put the title line in the top space and (here is where it gets to be a problem) that content seems to get locked there and will then continue to display when I stop using the Identify tool and instead just click on another feature for which a PopUp configuration has been defined. Nothing I do after that, short of reloading the page, will dislodge the old title from the line adjacent to the close button in the PopUp window.
I know the old style InfoTemplate is on its way out, but is it possible for both it and the new PopUp window to be used in the same viewer? Maybe there is a fundamental clash between them and I need to translate all of the configuration in my Identify widget configuration file into PopUp configurations.
I am pretty new to this, so any help is appreciated!
Don Taylor, City of Ventura, CA
