Print Task API3 AGS 10.1 Layout Option CustomTextElements
6780
12
07-15-2012 11:52 PM
SchoppMatthieu
I'd like to know how to handle the "customTextElements" property of the LayoutOptions (PrintTask) back in the template.mxd
"title" and "author" use standard "dynamic text" - (e.g. <dyn type="document" property="title"/>)
What about customTextElements ?
Can we send other objects like an overview map to the printing-geoprocessing service ?
Can I find somewhere some documentation about how to extend the printing geoprocessing tool ?
Cheers,
SchoppMatthieu
Thank you very much for your help Dasa 🙂
I finally extended the print service with Python, add a "String" parameter called whatEver.
When the client call the service and pas a whatEver parameter, python handle it using ListLayoutElements in the mxd :
Comments = arcpy.GetParameterAsText(3)
if Comments == '#' or not Comments:
    Comments = ' '
for whatEverString in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
    if whatEverString.name == "WhatEver":
        whatEverString.text = Comments
RaduMihai
I have the same question I read all the documentations I could get my hand on however I found nothing concrete about how to use this customtextElements,there are no samples,tuts..
I am wondering in which way can this customTextElements become useful for a Javascript developer
My problem started when the question was raised: "How can I include any other optional text on the printed version of the map ?"
SchoppMatthieu
Finally I had to come back on this one and I've got it working :
In client side (javascript) :
printTemplate.format = MapConfig.printService.format;
printTemplate.layout = PrWidget.mapTemplatesFilteringSelect.get('displayedValue');
printTemplate.preserveScale = false;
printTemplate.layoutOptions = {
    titleText:PrWidget.titleTextBox.get("value"),
        customTextElements:[
        {Entite:PrWidget.entiteTextBox.get("value")},
        {Rue:PrWidget.rueTextBox.get("value")},
        {CodePostal:PrWidget.codepostalTextBox.get("value")},
        {Ville:PrWidget.villeTextBox.get("value")},
        {Contact:PrWidget.contactTextBox.get("value")},
        {Mail:PrWidget.mailTextBox.get("value")},
        {Telephone:PrWidget.telephoneTextBox.get("value")},
        {Fax:PrWidget.faxTextBox.get("value")}
It will automatically search for text elements in the mxd template base on textElement elementName that matches the keys (if I've got a textElement which elementName in "Entite" in my mxd, then it will update it with the value I defined).
This prevent to add "extraParameters" just for updating text in the template.
