warning: unable to bind to property 'region' on class 'Object' (class is not an IEventDispatcher) warning: unable to bind to property 'summary' on class 'Object' (class is not an IEventDispatcher) warning: unable to bind to property 'name' on class 'Object' (class is not an IEventDispatcher)
<?xml version="1.0" encoding="utf-8"?> <s:View xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" title="Map" creationComplete="pointsXML.send()" viewActivate="init()"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.GeometryServiceEvent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import flashx.textLayout.events.DamageEvent; import mx.collections.ArrayCollection; import mx.containers.VBox; import mx.controls.Alert; import mx.controls.Image; import mx.controls.Label; import mx.controls.List; import mx.events.FlexEvent; import mx.rpc.AsyncResponder; import mx.rpc.events.FaultEvent; import mx.rpc.events.ResultEvent; import mx.utils.ObjectProxy; import spark.components.Scroller; import spark.components.TextArea; [Bindable] private var dataProxy:ObjectProxy; private var pntList:XMLList; private var attributes:Object; private function init():void { pointsXML.send(); } protected function pointsXML_resultHandler(event:ResultEvent):void { var gArr:Array = []; var myGraphics:Array = []; var x:XML = XML(event.result); pntList = x..entry; for (var i:int = 0; i < pntList.length(); i++){ var latlong:Array = pntList.point.split(" "); attributes = new Object(); attributes.name = pntList.name; // attributes["name"] attributes.region = pntList.region; // attributes["region"] attributes.summary = pntList.summary; // attributes["summary"] var myPoint:Geometry = new MapPoint(latlong[1], latlong[0], new SpatialReference(4326)); var coordGraphic:Graphic = new Graphic(myPoint,null,attributes); gArr.push(myPoint); myGraphics.push(coordGraphic); } var outSR:SpatialReference = new SpatialReference(3857); geometryService.project(gArr, outSR, new AsyncResponder(projectCompleteHandler, projectFault, myGraphics)); } protected function projectFault(event:FaultEvent):void { Alert.show(event.fault.faultString); } protected function projectCompleteHandler(result:Object, token:Object):void { var pRslts:Array = result as Array; for (var pg:int = 0; pg < pRslts.length; pg++) { var pGeom:Geometry = pRslts[pg]; token[pg].geometry = pGeom; token[pg].addEventListener(MouseEvent.ROLL_OVER, mClick); token[pg].addEventListener(MouseEvent.CLICK, click); } graphicsLayer.graphicProvider = token; } private function click(event:MouseEvent):void { var gra:Graphic = event.target as Graphic; navigator.pushView(newView, gra.attributes); } private function mClick(event:MouseEvent):void { var gra:Graphic = event.target as Graphic; var vbox:VBox = new VBox(); vbox.height = 20; vbox.width = 150; var label4:Label = new Label(); label4.text = gra.attributes.name.toString(); vbox.addChild(label4); map.infoWindow.content = vbox; map.infoWindow.closeButton.height = 0; map.infoWindow.closeButton.width = 0; map.infoWindow.show(gra.geometry as MapPoint); } protected function pointsXML_faultHandler(event:FaultEvent):void{ Alert.show(event.fault.message); } ]]> </fx:Script> <fx:Declarations> <s:HTTPService id="pointsXML" url="http://m.gstaadrealestateservices.com/android/properties.xml" result="pointsXML_resultHandler(event)" resultFormat="xml" fault="pointsXML_faultHandler(event)"/> <esri:GeometryService id="geometryService" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/> </fx:Declarations> <s:navigationContent> <s:Button width="80" height="70" click="navigator.popView()" icon="assets/backbutton.png"/> </s:navigationContent> <esri:Map id="map" x="0" y="0" height="690" openHandCursorVisible="false"> <esri:extent> <esri:Extent xmin="-467799" ymin="5253018" xmax="2171419" ymax="6627661"/> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer id="graphicsLayer"> <esri:symbol> <esri:SimpleMarkerSymbol alpha="0.9" color="0xedf2f7" size="18" style="circle"> <esri:SimpleLineSymbol color="0x003369" width="2" alpha="1" style="solid"/> </esri:SimpleMarkerSymbol> </esri:symbol> </esri:GraphicsLayer> </esri:Map> </s:View>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"> <s:layout> <s:VerticalLayout /> </s:layout> <fx:Script> <![CDATA[ import mx.controls.Alert; import mx.utils.StringUtil; private var someText:String = "some text"; protected function onSubmitClick(event:MouseEvent):void { someText = txtInput.text; var message:String = StringUtil.substitute("someText value = '{0}'\ntxtInput text = '{1}'\nlblOutput text = '{2}'", someText, txtInput.text, lblOutput.text); Alert.show(message); } ]]> </fx:Script> <s:TextInput id="txtInput" /> <s:Button label="Submit" click="onSubmitClick(event)" /> <s:Label id="lblOutput" text="{someText}" /> <!-- Data binding will not be able to detect assignments to "someText" ... in line 33 ... --> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"> <s:layout> <s:VerticalLayout /> </s:layout> <fx:Script> <![CDATA[ import mx.controls.Alert; import mx.utils.StringUtil; [Bindable] private var someText:String = "some text"; protected function onSubmitClick(event:MouseEvent):void { someText = txtInput.text; var message:String = StringUtil.substitute("someText value = '{0}'\ntxtInput text = '{1}'\nlblOutput text = '{2}'", someText, txtInput.text, lblOutput.text); Alert.show(message); } ]]> </fx:Script> <s:TextInput id="txtInput" /> <s:Button label="Submit" click="onSubmitClick(event)" /> <s:Label id="lblOutput" text="{someText}" /> </s:Application>
