Automated scripting - what's required?
956
05-09-2017 06:05 AM
AndrewHargreaves
Occasional Contributor II
Hello
I'm attempting to write a script that I hope can be ran every 15mins using Microsoft Task Scheduler. Please can someone tell me: Do I require ArcGIS Pro and/or Portal on that machine - pretty certain I don't but just checking.
Tags (1)
JimCousins
MVP Regular Contributor
What does the script do? Does it reference any of the ESRI object library?
Regards,
Jim
AndrewHargreaves
Please see my other post outlining what I need - I was hoping to do it all via Python API. I'm struggling to understand how to deploy the script I have (nearly) working on my local machine -which has both ArcGIS Desktop and Pro on it - onto a server that has no Esri products.
KaushikMysorekar
New Contributor III
Hi Andrew,
IF your script imports the arcpy module for required functionality then you would need to have either Desktop/Pro, Engine or Server installed on your production server for your scripts to work.
IF you are using the ArcGIS API for Python then here are the deployment options: Install and set up | ArcGIS for Developers
