can a geometry object be used with select layers by location?
1437
5
10-02-2020 12:23 PM
ArthurAbbott1
I am trying to use Select Layers By Location tool in Python.
I have a polygon feature class that I would like to iterate though each feature and do a select layers by location in order to get a list of layers that each polygon intersects with.
Can I use a search cursor to iterate through the polygons and pass the geometry to Select Layers By Location as the select_features parameter?
extents = sys.argv[1]
#polygon shapefile containing 4 polygons
try:
    arcpy.env.workspace = "C:\Dataset.gdb"
    #get extents spatial reference
    ex_sp = arcpy.Describe(extents).spatialReference
    fcs = arcpy.ListFeatureClasses()
    with da.SearchCursor(extents,["SHAPE@"]) as scursor:
        for row in scursor:
            boundary = row[0]
             Output_Layer_Names, Count = arcpy.management.SelectLayerByLocation(in_layer=fcs, overlap_type="INTERSECT",
                 select_features=boundary, search_distance="", selection_type="NEW_SELECTION",
                 invert_spatial_relationship="NOT_INVERT")
            print(Output_Layer_Names,Count)
except:
Any help is appreciated
Arthur
JoshuaBixby
MVP Esteemed Contributor
Your issue is with this:
You are trying to unpack the Result object's outputs, but you haven't given the correct number of variables to unpack into.  The following should work:
_, Output_Layer_Names, Count =
DanPatterson
what trackback error did you get when you ran it?
... sort of retired...
ArthurAbbott1
too many values to unpack (expected 2)
I also get the same error if I try creating a new polygon object and passing that in
DanPatterson
this
then this
.... SelectLayerByLocation(in_layer=fcs....,
how many featureclasses are there? perhaps you want the first? slice with ....ListFeatureClasses()[0] perhaps.
It would be easier to reference with code formatting
/blogs/dan_patterson/2016/08/14/script-formatting
and if you dump the try-except block, you will still get real error messages
Also the help topic still says layers are required.  You can do geometry intersections using arcpy directly
JoshuaBixby
ArthurAbbott1
Yup, that did it.  Thanks.
