I'm attempting to build a simple script to migrate an Experience Builder app from a development to production environment but receiving 'NoneType' ojbect has no attribute 'metadata' on the final line.
The item_to_migrate is an object and does have a valid metadata property unless that's not the problem here?
from arcgis.gis import GIS
portal_password = '***'
user = '***'
dev_gis = GIS("https://***/portal", user, portal_password)
prod_gis = GIS("https://***/portal", user, portal_password)
item_to_migrate = dev_gis.content.get("1ff4d32bc2344739b6b4e4df61f5de08")
clone_result = prod_gis.content.clone_items(items=[item_to_migrate],folder="Asset")
Hi @ResourceAnalyst, are you sure that you are getting an object back on your item_to_migrate?
Things to look out for:
Hope it helps
Henry
The source data is already published and I have added those 2 flags but the same error above remains. Object from VS Code as below:
{'_portal': <arcgis.gis._impl._portalpy.Portal object at 0x000002623EF78370>, '_gis': GIS @ https://
*.com.au/portal version:10.3, 'itemid': '1ff4d32bc2344739b6b4e4df61f5de08', 'thumbnail': None, '
_workdir': 'C:\\Users\\*\\AppData\\Local\\Temp\\2', '_hydrated': False, 'id': '1ff4d32bc2344739b6b4e
4df61f5de08', 'owner': '*', 'created': 1698098887072, 'isOrgItem': True, 'modified': 170666283
8039, 'guid': None, 'name': None, 'title': 'Assets', 'type': 'Web Experience', 'typeKeywords': ['EXB Exp
erience', 'JavaScript', 'publishVersion:1.10.0', 'Ready To Use', 'status: Published', 'version:1.10.0',
'Web Application', 'Web Experience', 'Web Mapping Application', 'Web Page', 'Web Site', 'Metadata'], 'de
scription': 'Test to see if metadata gets populated.', 'tags': ['asset'], 'snippet': 'Simple app to main
tain assets for Land Team', 'documentation': None, 'extent': [], 'categories': [], 'spatialReference': N
one, 'accessInformation': None, 'licenseInfo': None, 'culture': 'en-us', 'properties': None, 'advancedSe
ttings': None, 'url': 'https://*.com.au/portal/apps/experiencebuilder/experience/?id=1ff4d32
bc2344739b6b4e4df61f5de08', 'proxyFilter': None, 'access': 'shared', 'size': 132816, 'subInfo': 0, 'appC
ategories': [], 'industries': [], 'languages': [], 'largeThumbnail': None, 'banner': None, 'screenshots'
: [], 'listed': False, 'ownerFolder': '7c3df485a8ff438c8d01f4af2e19b066', 'protected': False, 'commentsE
nabled': False, 'numComments': 0, 'numRatings': 0, 'avgRating': 0, 'numViews': 44, 'itemControl': 'admin
', 'scoreCompleteness': 20, 'groupDesignations': None, 'lastViewed': -1, '_depend': <Dependencies for 1f
f4d32bc2344739b6b4e4df61f5de08>}
Hi @ResourceAnalyst, What version of portal do you have deployed? and can you add the track trace e.g. the error that you get from the script?
Other methods you can try to use is collaboration or try using the group migration manger
arcgis.gis module | ArcGIS API for Python
is creates a package that you can import on the other system.
Thanks again,
Portal 11.1
Exception has occurred: AttributeError
'NoneType' object has no attribute 'metadata'
File "R:\Applications\Scripts\GIS\ArcGIS Enterprise\CopyPortalItemSimple.py", line 26, in <module>
clone_result = prod_gis.content.clone_items(items=[item_to_migrate],folder="Asset",copy_data=False,preserve_item_id=True)
AttributeError: 'NoneType' object has no attribute 'metadata'
Hi @ResourceAnalyst, I had a deep dive into this problem, and the only difference I can see is that your object does not look like it is correct, compared to one that I spun up, see below.
This might then suggest an API version problem for the ArcGIS API are you running your code out of ArcGIS Pro or a standalone instance, if standalone can you upgrade the ArcGIS Module if Pro which version are you running.
{'id': '361dcd0c4bec47fab3dbc4eac861cb52', 'owner': 'portaladmin', 'created': 1706849601820, 'isOrgItem': True, 'modified': 1706849622438, 'guid': None, 'name': None, 'title': 'Untitled experience 2', 'type': 'Web Experience', 'typeKeywords': ['EXB Experience', 'JavaScript', 'Ready To Use', 'status: Draft', 'version:1.10.0', 'Web Application', 'Web Experience', 'Web Mapping Application', 'Web Page', 'Web Site'], 'description': None, 'tags': [], 'snippet': None, 'thumbnail': None, 'documentation': None, 'extent': [], 'categories': [], 'spatialReference': None, 'accessInformation': None, 'licenseInfo': None, 'culture': 'en-us', 'properties': None, 'advancedSettings': None, 'url': None, 'proxyFilter': None, 'access': 'private', 'size': 1490, 'subInfo': 0, 'appCategories': [], 'industries': [], 'languages': [], 'largeThumbnail': None, 'banner': None, 'screenshots': [], 'listed': False, 'ownerFolder': None, 'protected': False, 'commentsEnabled': False, 'numComments': 0, 'numRatings': 0, 'avgRating': 0, 'numViews': 0, 'itemControl': 'admin', 'scoreCompleteness': 16, 'groupDesignations': None, 'lastViewed': -1}
