Greetings,
I am following the ArcGIS API for Python instructions. Where it states: "conda install /path_to_package_download_"
Which is the correct tar.bz for Python 3.11??
I used the conda consul install using:
"conda install \Users\ci000030\Downloads\win-64_arcgis-2.1.0-py39_3211.tar.bz2"
I got the following errors below. Can anyone assist to resolve the errors??
Downloading and Extracting Packages:
Preparing transaction: done
Verifying transaction: done
Executing transaction: / Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'certifi'
File "<frozen runpy>", line 189, in _run_module_as_main
File "<frozen runpy>", line 112, in _get_module_details
File "C:\Users\ci000030\AppData\Local\anaconda3\envs\defra\Lib\site-packages\arcgis\__init__.py", line 3, in <module>
from arcgis.auth.tools import LazyLoader
File "C:\Users\ci000030\AppData\Local\anaconda3\envs\defra\Lib\site-packages\arcgis\auth\__init__.py", line 1, in <module>
from .api import EsriSession
File "C:\Users\ci000030\AppData\Local\anaconda3\envs\defra\Lib\site-packages\arcgis\auth\api.py", line 17, in <module>
from requests.sessions import Session
ModuleNotFoundError: No module named 'requests'
done
ERROR conda.core.link:_execute(945): An error occurred while installing package '<unknown>::arcgis-2.1.0-py39_3211'.
Rolling back transaction: done
LinkError: post-link script failed for package <unknown>::arcgis-2.1.0-py39_3211
location of failed script: C:\Users\ci000030\AppData\Local\anaconda3\envs\defra\Scripts\.arcgis-post-link.bat
==> script messages <==
==> script output <==
stdout: jupyter nbextension command failed: map widgets in the jupyter notebook may not work, installation continuing...
stderr:
return code: 1
