I'm trying to connect to Portal for ArcGIS using the Python ArcGIS API and a user administrator account.
However, when I try to authenticate with the Python code, I get error: "Exception: User not allowed for this account"
URL= 'https://domain.name.com/portalgis'
ARCGIS_USER = 'user'
ARCGIS_PASSWORD = 'password'
gis = GIS (url=URL, username=ARCGIS_USER, password=ARCGIS_PASSWORD)
If I try to connect with API Rest, I can:
headers = {'content-type': 'application/form-data'}
payload = {
'f': 'json',
"username": ARCGIS_USER,
'password': ARCGIS_PASSWORD,
'client': 'reference',
'reference': URL,
"expiry": 21600
req = requests.post('{}/sharing/rest/generateToken'.format(URL),data=payload, verify=False)
# Extract the token
token = json.loads(req.content.decode('utf-8'))
token = token['token']
print ('--> TOKEN {}'.format(token))
Setting portal logging in debug mode, I'm getting: "com.esri.gw.oauth2.OAuth2Exception: Invalid redirect_uri at com.esri.gw.filters.SecurityFilter.doFilter(SecurityFilter.java:100) at ... at java.base/java.lang.Thread.run(Unknown Source)"
I'm using ArcGIS Enterprise v11.2. This problem occurs after upgrade from v10.8.1 (The privatePortalURL of portaladmin Home > System > Properties is set correctly).
